Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Intermittent one way transmission
pluto9
Sometimes when I receive an incoming call, I can't hear the person at the other end of a call, but they can hear me perfectly. If we clear the call down & re-establish it the connection, it is fine.
I will pass this now for you to one of TalkTalk's OCEs to pick your thread up and they will investigate it for you.
The forum is not real time 24/7 support, so depending on how busy they are & how many are working at any one time, this can take 24 - 48 hrs (excluding weekends & Bank Holidays). Alternatively, you can call the call centre or use on-line chat. The posts are responded to in time/date order, oldest first. So the fewer entries you make on your thread now, the sooner they will pick it up.
Otherwise, TT will not be able to tie up your forum username to your broadband account. Only you & TalkTalk have visibility of your details.
Hi pluto9
I've completed a line test which hasn't detected any faults. Have you tested with a different phone?
pluto9
Hi @OCE_Debbie
Thanks for that. Yes, I have tried another phone, but I don't think it is my line itself, more a faulty route that the call takes. It only happens when my daughter calls me, or I call her. It does not happen often, about once every couple of weeks.
One of us will hear a "dalek" type noise on the connection, which makes it difficult to hear the other person over the top of this noise.
Not that there is any connection in this, but we are both TalkTalk customers & both served off the same exchange.
Hi pluto9
Does your daughter not experience this fault on any other calls, only on calls to yourself?
Would it be possible to make a note of 3 example dates and times of when this fault has occurred, I can then pass this over to our Network Team for investigation.
pluto9
Hi @OCE_Debbie
Thanks. No, it only happens between the two of us as far as we are aware, but as calling each other forms the majority of our calls, this could happen on other local calls, although neither of us has noticed it with any one else.
So far the only one I can give you is
Sunday 30/07/2017 at 22:00
If you would be so kind as to enable PMs on my account, I will send you my daughter's phone number.
Hi pluto9
Thanks for your reply. You should now be able to send me a Private Message.
pluto9
Hi @OCE_Debbie
There has now been three calls, which I have included the details in a PM to you now.
Hi pluto9
I've raised this fault over to our Network Team for investigation.
Please post back on this thread in 24hrs and we can check for further updates.
pluto9
Bump
Hi pluto9
I've requested an update on this fault from our Network Team and I will post back on this thread as soon as I receive further information.
pluto9
Hi @OCE_Debbie
Just had another call like this between the usual two numbers. It occurred on:-
13/09/2017  19:04 approx
Pluto9
Hi Pluto9,
I can see that our network team are currently investigating, has anyone contacted you yet?
pluto9
Hi Chris,
No, but please can you ask them to contact my Son-in-Law about this, as he understands this much more than I do?
I'll PM you his details in a second.
Pluto9
Hi pluto9
Our Network Team have asked if you can retest and let us know if this fault is still present?
pluto9
Hi @OCE_Debbie
Have they actually found anything, because I did add another problem call only two days ago on the 14th?
Hi pluto9
I think they made some changes or completed work. Please let us know if you do experience this fault again.
pluto9
Thanks @OCE_Debbie I will do.
