Home Phone
International Saver for 12 months ???
Graham7
Super Duper Contributor
Message 2 of 2
Might have to phone Turkey and going to but on International Saver.  Can I just use this for one month and them remove it  ???
Talktalk forum is the best place to ask question and get things sorted.
1 REPLY 1
Gondola
Message 1 of 2
Hi @Graham7
You can add any TalkTalk Boost for just a month at a time and cancel at any time with just the first 30 days as a commitment.  Here's the information about Call Boosts.
The International Saver Boost gives you discounts on calls to Turkish landlines and mobiles.
The International Extra Boost gives you 1000 minutes of free calls from your landline to landlines in Turkey. If you also want to call Turkish mobiles, 1000 minutes for free, then it's International Max Boost.
GondolaVolunteer 2017-2021
 Like below to appreciate my help . . . Mark as solved + Accept as Solution
