Home Phone
LANDLINE WORKS VIA TEST SOCKET-NOW WHAT?
RockyPeli
Message 2 of 2
My landline has had no dial tone but my broadband has been fine. I followed the instructions to sort the landline issue and it works when plugged into the test socket. What therefore is the issue? Do I need a new cable from my landline to the microfilter? Or is it a problem with the faceplate? The instructions ended at testing it so not sure how to proceed now....thank you.
1 REPLY 1
Message 1 of 2
Hi RockyPeli
Which type of master socket do you have? Do you use a microfilter at the master socket or does it have a filter in the face plate?
Your guide to main phone sockets
