Land line received calls but can't dial out
5 REPLIES 5
GaryR2
My mother's land line will receive calls but if she tries to dial out , she gets engaged signal. She's 85 and worried.
OCE_Arne
Hi @GaryR2
Can you add the  number to your community profile and we will log a fault.
GaryR2
Number now added.
OCE_Arne
I will run some tests and get back to you.
OCE_Arne
Hi GaryR2
Line tests are not detecting any faults.
Can you connect to the test socket behind the faceplate and see if the phone works.
Jez Hyland
My landline can receive incoming calls so no fault. However when dialing out there is an automated message from talk talk saying the number needs reactivating. All bills paid by DD and are up to date. Please help as I need the number active for an important conference call.
