My Landline is not working, as of two hours ago!
I've done the usual, tried another handset directly into the test socket.
There is no dial tone.
When dialed the number appears to be engaged...
Fortunately my internet still works!
I'm aware there appears to be some outtages, however I wanted to log this just incase...
Tried to login for text updates - not sure if this was accepted...
I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
Thank you!
I have checked and these details are in my personal profile....
As it's now Tuesday... is there any news/update on my ladline problem...?
Incidentally they appear to be putting an additional "green box" next to the one opposite my home...
I wonder is what caused the loss of my landline , and have I got to wait until these works have concluded before my line is reinstated?
Hi @AlanB4
Looks like the fault is part of a wider problem latest update is : "This circuit is a part of common fault. Linked with the lead fault id is “LN6CMF40” as per the latest updates. Duct work is required. It has been passed to the relevant team. The Required By Date (RBD) provided by contractors is as 16/11/18. Please check Fault Tracker for further update on 19/11/2018."
Sorry again for the inconvenience caused.
