Landline not ringing/Unknown caller id/Can't disable call safe
21 REPLIES 21
pbfisher30
I have a problem which was first reported to the talktalk phone support team on 11Dec . To date the problem has still not been fixed. Callsafe is enabled and cannot be disabled even though I have tried to switch it off on many occasions. The engineers have also tried to disable callsafe but it still shows as active on my account. The phone is ringing silently for incoming calls and the caller id is showing as withheld. My assumption is the callsafe is not identifying the caller so the call rings silently as though calls are being screened out. Outgoing calls are fine and no issue with broadband. Please help. A promised five day resolution has not materialised.
Many thanks,
pbfisher30
OCE_Debbie
Hi pbfisher30
  • Name
  • Telephone number
  • Alternative contact number
pbfisher30
Hi Debbie, thank you for your response. I have updated the profile now with my details.
Look forward to hearing.
pbfisher30
OCE_Chris
Hi pbfisher30,
Thanks for updating your profile. What happens if you call your landline from your mobile, what do you hear on the mobile?
pbfisher30
Hi Chris, it just rings silently. If the answer machine is on you can leave a msg but silent ring.
Thanks,
pbfisher30
OCE_Arne
Hi @pbfisher30
Can you try again to test in a few hours,  We have re-enabled and then disabled callsafe in the past few minutes it can take upto 2 hours complete.
Let us know how it goes.
pbfisher30
Hi Arne,
tested today. phone is still ringing silently so this hasn't fixed the issue.
thanks,
pbfisher30
OCE_Arne
Hi @pbfisher30
I have passed this to our network team to solve.
Sorry its still ongoing.
pbfisher30
I cannot make outgoing calls today. incoming calls now fwd to a recorded message that states the line is unable to receive calls at present.
pls assist urgently
OCE_Arne
OCE_Arne
Hi @pbfisher30
A fault is now being detected on the line.
I can put a divert to your mobile for over the weekend as Openreach dont work weekends
pbfisher30
hi Arne, thank you for the quick response. the line seems to be working again just now.
OCE_Arne
Ok we are still working on the callsafe issue, which may have caused the temporary issue
pbfisher30
Hi this problem still has not been resolved. Initially reported to Talktalk two months ago.
We have narrowed it down to withheld numbers being blocked even though this feature is not enabled.
Please assist.
thank you.
Gliwmaeden2
I'll re-escalate this thread for you, @pbfisher30, as it's been a while since there was activity on it and it may have dropped out of the workflow.
Look for a reply in the next couple of days or so.
OCE_Arne
Hi @pbfisher30
I will check for an update on this, but a look on our server shows that callsafe is not on the line, indicating it has been resolved.
Do you know if a caller with a withheld number hears a recorded message?
pbfisher30
Hi Arne,
callsafe has been disabled so there is no recorded message. However withheld numbers only ring silently so there is still an issue.
Thank you
OCE_Arne
Hi @pbfisher30
Ok that is a different issue, can you attach the phone to the test socket (behind the faceplate) and retest, or if possible try a different handset.
Let me know how that goes.
pbfisher30
Varying results. A different DECT handset gives the same problem but a regular bog standard, phone does ring. can you confirm this is not a software issue at your end before we have to dismantle the socket?
OCE_Arne
I'm quiet sure that its isn't anything related to any call features , My only guess is it could be down to low voltage on the line.
