on 09-01-2022 06:13 PM
I've reported the fault through the automated phone system, and been told there's not a fault. There is! There is no ring tone, I can't make or receive any calls. I've tried the phone in another phone socket in the house ( I have 2 different lines for 2 separate numbers) and it works fine. When I call TalkTalk back it asks me if I am phoning about the same fault. When I say 'yes', it tells me they are closed and to go on to talktalk.help/update, which I've done and is no help whatsoever! TalkTalk, this is not acceptable. Please get back to me asap.
My internet is working.
This is a residential line, but I use it for work, so it is essential this issue is sorted.
Thank you.
Pete
on 10-01-2022 09:04 AM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 09-01-2022 07:36 PM
@PeteDW1 click on your avatar at the top RHS of the page and then MY SETTINGS > LAUNCH PROFILE WIZARD
on 09-01-2022 06:42 PM
Sorry, bit dim here, how do I do add my phone number?
on 09-01-2022 06:36 PM
@PeteDW1 please add your landline number to your community profile, that is how staff identify you.
It is only visible to staff, do not post it here in public.
on 09-01-2022 06:32 PM
Thanks. I just noticed someone called Craig had sent a message on this forum with a similar problem.
There is no dial tone, just quiet static. When I ring in, it gives the engaged/line busy sound/message.
Yes, internet is working fine.
09-01-2022 06:26 PM - edited 09-01-2022 06:28 PM
@PeteDW1 put your phone number in your community profile and wait for a response from a staff member early next week.
Do you actually mean no DIAL TONE and is the internet working normally ?
What message do you get when you try to call the number ?
If you are using the line for business you might be better off getting an appropriate contract with a better SLA.
PS. Who is Craig and what has he got to do with the issue ?
