on 25-06-2022 01:56 PM - last edited on 25-06-2022 02:50 PM by Gondola
We Have No Dialling Tone,are Unable To Make Or Receive Calls. We've Done What We Are Able To Do. Can You Please Test Our Landline For Any Fault. Thanks.
on 27-06-2022 07:15 AM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 25-06-2022 03:14 PM
Hi DCmc1979
Your incoming calls are going straight to Voicemail.
To supplement the advice from Martin here's the TalkTalk advice: I can't make or receive calls - make sure no handset is off the hook and start with the Try a different handset plugged into the master 'phone socket assuming you haven't included that in your earlier tests.
Like below to appreciate my help . . . Mark as solved Accept as Solution
on 25-06-2022 02:40 PM
@DCmc1979 there are no staff here until Monday.
If you still have internet go to Service Centre and do a check.
Report the issue by calling 0345 172 0088 or Live Chat if you can get online.
