No Landline
14 REPLIES 14
dclholly
My landline appears to be dead.  I have plugged a phone into the main socket but get no dial tone.  I still have broadband though.
Suggestions please?
Paul
Divsec
Hi @dclholly your post has been flagged for assistance and you should hear during the day. Have you tried calling in using a mobile?
OCE_Karl
Hi dclholly
Tests are showing a Disconnection fault.
I've logged this to Opereach so they can take a look.
dclholly
Thanks Karl for the quick reply
Hopefully Openreach will sort it out
OCE_Karl
No Problem, Glad to help.
dclholly
So OpenReach came out (twice) and identified a fault 150m up the road.  They have done a temporary fix and will be coming back to fix with a new cable.  Currently the Landline has been restored, but my broadband speed is only around 17Mb/sec rather than the usual 37Mb/s.
OCE_Arne
Hi @dclholly
Once Openreach complete the work your speed should return.
Did they say when they would be back?
dclholly
Unfortunately no date given
OCE_Arne
Ok , What i suggest is to continue to monitor for the rest of the week and if the speed are below your minimum speeds next week we can pass it back as a new fault.
dclholly
OK - I'll update you at the weekend.
OCE_Debbie
dclholly
I'm still experiencing slow speeds - 17mbps down, 7 mbps up.
Can we escalate this please?
OCE_Michelle
Hi dclholly,
I'm sorry for the delay. The line test is still detecting a possible fault, however the sync speed and profile both look ok. Could you try switching the router off for a full 30 minutes and then run another speed test please as this will reset the current session.
Is the voice service now ok with no noise?
dclholly
All good now - many thanks for sorting it out
OCE_Michelle
Hi dclholly,
Excellent, I'm glad to hear this 🙂
