No dial tone with continuous engaged tone.
my home phone has no dial tone with a continuous engaged tone on the line. the broadband is okay. no incoming calls can be received nor outgoing calls can be made. nothing will clear the line of the engaged tone. our immediate neighbours are having the same problem as they are talktalk customers also,
Your neighbours I'll need to report their issue themselves.
A test is showing a loop fault.  This can be caused by internal wiring, faulty filter  or a faulty handset.
Can you unplug everything from the phone socket and test an alternative handset (or test your handset at a friends or neighbours), and connect a phone directly into the Test Socket.
If the fault exists at the test socket then this will require an engineer.
