Home Phone
Noisy and crackling line
jimandann31a
Message 10 of 10
For months we've had a crackling and occasional hissing noise on our landline. It's intermittent, but recently it's become more or less constant, to the point where we’re struggling to be able to make or receive a call. Also, there's an occasional echo on one or both sides of the call - when someone speaks, they can hear themselves a fraction of a second later - very annoying!
We've tried disconnecting all extensions, and plugged a corded phone directly into the test (master) socket - and the problem's still there. We’ve tried changing all the microfilters, different phones etc, all to no avail.
I've tried to "chat" with an agent, but it's an exercise in futility – 2 hours of going round and round the same scripted questions and answers, to the point where I wonder if they actually read what I've typed  (if someone from TT is reading this, please retrieve the chat transcript and assess this for yourself).
I’m almost certain this is a line (i.e. Openreach) issue, but I understand there needs to be some vetting of the fault before I can book an engineer. Can someone help please?
9 REPLIES 9
Message 1 of 10
Hi jimandann31a
The engineer has also left notes to advise that work was completed at the cabinet. They also said that they gave advice regarding location of the router.
jimandann31a
Message 2 of 10
The Openreach engineer visited on Monday and although he couldn't find any immediate causes for the problem, he swapped over the line to a new connection at both the cabinet and the exchange (or so I believe - I'd be interested if there's any more detail you can provide). Since then, the line has been perfect 😀
jimandann31a
Message 3 of 10
PM sent, can you confirm when the engineer is booked please?
Message 4 of 10
I'll drop you a PM to confirm some details so we can get the engineer booked for you.
jimandann31a
Message 5 of 10
Apologies, meant to add that yes: we've tried several different phones, both corded and cordless.
jimandann31a
Message 6 of 10
Hi Debbie,
Yes - with only a corded phone plugged directly in to the master socket (the test socket behind the faceplate), and nothing else connected, we still get the crackling.
Jim
Message 7 of 10
Hi jimandann31a
Thank you. The line tests are clear - No faults detected.
Thanks for also confirming that you have tested with a different phone at the test socket. Was the router also removed from the line?
The next step will be to arrange an Openreach engineer visit.
jimandann31a
Message 8 of 10
Should be there now, thanks
Message 9 of 10
Hi jimandann31a
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
