on 16-01-2022 06:20 PM
I have just been called on my mobile by my mother to tell me my landline is not working. Checked the handset and have a dial tone. Made a phone call and all ok. Called my landline from my mobile and..... yup - nothing. Just a bissing sound.
So I know the socket is workiong as Broadband is fine and I can make calls. Just no one can reach me...
I have run a service check and apparently everything is working in my area. Umm... I think not.
I'm in the BH22 area if anyone else has experienced the same issue.
on 17-01-2022 01:35 PM
OK, let me know when you test with another splitter and we can follow up.
on 17-01-2022 01:10 PM
Hi Karl
I have cordless handsets. I have not touched sockets for weeks and weeks now. It was working fine and just stopped. I have just checked again and it appears to be working. Looks intermittent though - not sure if it is a line splitter i have in the socket. I will get another and see if the problem goes away.
thanks
on 17-01-2022 11:56 AM
Hi Paul
Tests are showing a loop fault within the property.
Can you test another phone handset directly at the 'Test Socket' to rule out a handset or wiring issue and let me know if this still fails.
on 16-01-2022 08:36 PM
Hi @Paulsteed your post has been escalated and you should hear back tomorrow.
