Nuisance calls
3 REPLIES 3
funkyred
I keep getting a lot of calls supposedly from TT saying my internet is about to be disconnected, which I know are scams. At first they were all from the same area code, so I was able to block them. Now unfortunately they are from a range of numbers i.e. 012, 022, 015, the list goes on.
if anyone has any ideas as to how to stop them, I would be eternally grateful.
Can CallSafe help here?
Geoff
chrisb1953
Whizz Kid
I too used to get plenty of similar calls but they have totally stopped since I setup callsafe.
funkyred
Thanks Wizz Kid
Gondola
Hi @funkyred
About CallSafe is definitely your best friend.
Gondola - Volunteer 2017-2021
