on 11-05-2022 09:24 AM
Good Morning
My phone will not receive incoming calls from TT numbers and will not allow me to make outgoing calls. Incoming calls from mobiles are OK. I have removed the plate from the master socket and connected an analog phone with the same result. I have reported to fault on 08704441820 and although the fault reported was for the phone, the reply text received stated that my broadband was working (I KNOW THAT) and NO mention of the phone not working. I tried to report the fault again and TT's robot said TT were closed. The 'Live Chat' is also not working.
A relative, also a TT customer, has the same fault.
I have been trying for more than TWO hours trying to get Talk Talk's robots to accept that there is a fault with their phone system and I have run out of options. Are there any real people at TT?
We really shouldn't have to try to get faults fixed via a forum.
As 80 year old pensioners with health issues, we need our telephone as a lifeline.
I have had enough, we can do without all this aggro wihich revolves around TT's inability to provide effective real people support for their customers. They need to remember that it's the customer that pays their wages/dividends. We have been customers of TT for many years but at our contract's end I will be considering my options....Cheapest is not always the best.
on 11-05-2022 11:14 AM
loop fault still showing, next option is to arrange an engineer.
I'll drop you a PM with the details to confirm.
on 11-05-2022 11:07 AM
I disconnected per your message and reconnected after 10 minutes. Any result?
on 11-05-2022 11:03 AM
Can you remove all equipment from the socket and let me know when done so I can retest before we log this for an engineer.
on 11-05-2022 10:57 AM
I have now reconnected
on 11-05-2022 10:42 AM
A line test is showing a loop fault close to the premises. Can you open the test socket and remove all equipment connected to it and reply back when done so I can retest again with nothing connected.
on 11-05-2022 10:33 AM
I have already tried this, I have disconnected our phone system and connected an old analog phone direct to the test socket.with the same result. The fault is outside of our property. A relative with TT is having exactley the same problems.
on 11-05-2022 10:22 AM
Hi Greecian
Would it be possible to connect the phone only at the test socket just for testing purposes to see if the fault is still present in this set up?
I can also run a line with just the phone connected.
on 11-05-2022 10:20 AM
I'm now having problems replying to you....The phone is not connected via the master socke, my broadband won't work if it is.
on 11-05-2022 10:05 AM
Hi Greecian
The line test is detecting a potential fault towards the property. Is the phone still at the test socket at the moment?
