Home Phone
Phone rings but get static when answered no dial tone can't ring out
hughwpearce
Message 13 of 13
Phone will not receive calls just get static when I answer caller id is correct.  Even though I pick up phone caller still gets ringing.  Tried to make call but no ringing/tone.
Have tried replacing filter and connecting to master socket the old phone used to have illuminated buttons but is dead with no tone,  Internet is OK.  Have tried various phones
12 REPLIES 12
Message 1 of 13
Thanks for the update 🙂
hughwpearce
Message 2 of 13
Appears to be working OK now
Thank you
Message 3 of 13
If you don't hear anymore in the next 24hrs then please let us know and we can re-check for an update on the fault for you.
hughwpearce
Message 4 of 13
Thanks the internet seems a bit on the blink as well.  The engineer said this might happen the last time they fixed it as it's effectively working on one wire
Message 5 of 13
I've logged this over to Openreach for investigation.
hughwpearce
Message 6 of 13
The fault has come back presumably someone has bust another cable
Message 7 of 13
Glad this is now sorted.
hughwpearce
Message 8 of 13
Engineer sorted it wire had had snapped off in junction box apparently
Message 9 of 13
Hi hughwpearce
The engineer has investigated and located the fault. This fault has now been passed to the local network team for further work. Review date is 13/7/2021.
Message 10 of 13
Hi hughwpearce
Sorry for the delay.
Openreach have left notes to advise that the line engineer is due to investigate this fault today. We should receive further updates tomorrow.
Message 11 of 13
Still faulty not heard from openreach
Message 12 of 13
I'm sorry to hear this. The line test has detected a possible external line fault so I've passed this over to Openreach now to complete an external line investigation. If you don't hear any more over the next 48hrs then please let us know and we can re-check for an update on the fault for you.
