Home Phone
Potential Line Fault
whingebag
Message 8 of 8
The incoming telephone line from the pole to my home is strained.  Where it attaches to my wall it’s pulled the bracket from the wall, it’s only being supported by 2 of the 4 bolts.
I think the issue has been caused by the weight of birds resting on the cable. I need an engineer to attend and re-secure the bracket so it prevents total failure please.
Chris G.
7 REPLIES 7
Message 1 of 8
Hi whingebag
If you do experience any issues with the line/connection then please let us know and we will run further line tests.
Message 2 of 8
if your line tests are indicating normal service then there is no need to involve Openreach at this time.
thanks
Whingebag
Chris G.
Message 3 of 8
I've just re-run the line tests now to see if they detect any potential faults and they are both still clear at the moment.
If you think that this outside cabling is affecting your connection or voice service then we can book an Openreach engineer visit to the property to investigate, however I would just need to advise that this may or may not be chargeable depending on the engineers investigation.
Would you like us to arrange an engineer visit with you?
Message 4 of 8
Hi and thanks for the Openreach information.
i filled the form out and submitted it to them last night.
I received a text response this morning basically telling me to report it to you.
Whingebag
Chris G.
Message 5 of 8
Hi @whingebag
Sorry for the delay.
Because there is no fault with the service we cant log it to Openreach as this would generate a engineer charge. However there is a way that you can report this as damage to the network using the information in this link. https://www.openreach.com/help-and-support/damage-health-and-safety
Hope that helps
Message 6 of 8
Hi, there is some noise on the line, slight crackling although the noise is not making it difficult to hear a caller yet.
 I’ve attached a couple of photos that show the issue that needs to be repaired.
thanks
Chris G.
Arne-TalkTalk
Message 7 of 8
Hi @whingebag
Thanks for you post.
Are you experiencing any service issues with the line, Ie noise, crackling etc
