Problems calling a specific number
8 REPLIES 8
Whizz Kid
I have a very odd case. I have not been able to dial out from the home phone to one particular number. All other numbers work fine.
I have tested with different phone same result. If I use the mobile there are no issues.
The person at the other end has no issues with incoming calls and has checked their end?
It rings once then goes dead.
Any ideas?
Hi @bluerouter
It sounds like the recipient might have inadvertently blocked your number.
Whizz Kid
We thought that as well, but its been checked from the other end by the provider and we checked the phone.
Ok, are you manually entering the number, or are you using speed dial function?
Whizz Kid
We followed the TalkTalk help pages and have tried from two different phones.
We direct dialled the number.
Thanks for the help.
Can you add the number that you are trying call into your private notes section of your community.
Whizz Kid
Will do. Thanks
Whizz Kid
Hi Arne,
Any news or thoughts on this?
