Have been trying to use Last Caller Barring facility for the past few days (14258) All I am getting today is silence. I had dialling tone then silence yesterday. Rang 150 & was told no problem at that end & to check LCB still ticked in my Boosts (it is) then, if I still had problem try to get it fixed online! Can anyone help please.
@lizevans55 If you start your own topic then the OCE will gladly look into this for you.
I have had problems for a week with it not working.
Tried live chat and they were no help at all. Even rang off without asking if I was happy.
Then tried calling and I was told it may be a technical problem.
I have switched it off then a few days later turned it back on through preferences.
Unfortunately I have come to the conclusion its not going to work and nobody at talktalk cares.
Can you please try and retest the last caller barring service.
Hi OCE-Arne
Tried this morning & am glad to say it is back up & running. Thank you
