Home Phone
Removing Call Divert Boost
Tosher
Message 4 of 4
Hi. I applied Call Divert Boost over a month ago but don't need it now. However I am unable to remove it as tick box is shaded grey. Any help appreciated. Paul
3 REPLIES 3
Tosher
Message 2 of 4
Thanks for your swift response, Arne. My mistake.
All the best.
Arne-TalkTalk
Message 3 of 4
Hi @Tosher
Thanks for your post.
Boosts are required to remain active for 30 days.  you added it on the 13th Oct, you will be able to remove it 14 Nov
