on 05-11-2021 10:13 AM
This morning, my land line developed static and no dial tone. I have tried dialling a number and still more static and no dial tone. When calling my landline with my mobile, I get the engaged tone. I have tried all the recommended step to see if this a problem within my home like using another phone, using the master test socket, etc. and it still has static and no dial tone.
Further, my internet has slowed and disconnecting frequently. When I did the tests on my landline, it says that my device is in 'low performance mode' (on all my devices) even though they have been changed to maximum output.
on 05-11-2021 11:32 AM
ok thanks
on 05-11-2021 11:24 AM
Tests are not showing anything conclusive.
As you have tested an alternative handset at the test socket then the next option is to book out an engineer for you.
I'll drop you a PM for some details.
on 05-11-2021 11:00 AM
Hi Karl
Done as requested
on 05-11-2021 10:48 AM
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
