Talktalk Online Defence for PC
1 REPLY 1
KEJordan
Recently the Desktop button and Taskbar button icons have disappeared although they do still work. I have uninstalled Supersafe and reinstalled it but this issue has not changed. I can't find the icons anywhere in my PC files.
Gondola
Hi @KEJordan
Don't worry about it. The functionality isn't impaired.
The issue is known to TalkTalk and f-Secure and a fix is being worked on that will correct the missing icons in a future automatic update.
If you wish to do some investigating then have a look at this thread where other members have come up with a workaround.
Gondola - Volunteer 2017-2021
