Talktalk landline numbers
1 REPLY 1
Hi has you can see I am new to this so here goes Hi all .  Does anybody know were I can get a copy of any talktalk landlie numbers for such things has recovering messages left on my landline wile I was out and if possible any others that I might need  Thanks for your help Brian
Hi Brian
Here's the advice about Using TalkTalk Voicemail and how to listen to messages, including numbers, left on your landline whilst you were out. There's a video to watch which explains it all.
In relation to just the numbers I have a phone that keeps a record in the handset of the incoming calls where the number was not withheld by the caller.
I also have activated TalkTalk CallSafe and all the numbers I approve and block are listed in MyAccount, if not withheld by the caller.  A printed list of all calls incoming is a feature that's been promised in CallSafe but we're awaiting that as a feature addition.
I hope that's the information you're looking for and do post back to let me know.
 Gondola - Volunteer 2017-2020
