on 24-01-2022 01:25 PM
I cannot phone Malta on my international max I get a male voice saying no routing found on a couple of numbers I tried . If I get a phone call from Malta it registers but there is nothing on the line. This is been happening since last Friday 21st Jan 21. I tried UK numbers and mobiles but no problems. I thought if it was a problem on international lines it would have sorted by now.
Any suggestions please
on 26-01-2022 06:40 AM
Hi the1malt
I'm so glad to hear that this is now working ok 🙂
If you do experience any further issues then please let us know.
on 25-01-2022 09:58 PM
Hi Debbie today I tried the same numbers to Malta and everything is back to normal so I presume it was some international glitch so thank you for trying to help me but as I said I tried the numbers and they worked perfectly sorry for the inconvenience
on 25-01-2022 07:19 AM
Hi the1malt
I'm just sending you a Private Message to confirm some details so we can investigate this fault.
Please can you also add the number you are trying to dial and the dates/times you tried calling this number to the Private Notes section of your Community Profile.
on 24-01-2022 10:48 PM
I tried automatic dialling then I tried manual dialling tried to phone three different Malta phone numbers used home wireless Phone and used a hard wired phone and I keep getting a male robotic type voice saying something like
"no routes found" and up to last Thursday the 20th the lines were perfect
on 24-01-2022 01:29 PM
Can I just confirm, are you dialling the numbers manually or using speed dial? Prior to this did these numbers all go through ok?
