Unable to switch off Call Safe
9 REPLIES 9
Hello, i turned call safe on to try it, but don't like it. now it will not turn off after several attempts i'm now here.  Please help.
get this "Callsafe has now been switched off. Please note it may take several minutes for the feature to be deactivated" . but has no effect
Hi nickym
I've checked, and CallSafe showing as OFF.
Sorry for any confusion caused.
Same issue - have tried switching off from CallSdafe screen - no joy. Spoke to "Trevor" at CS this morning, said he had switched it off, but it's still on! Can anyone help resolve this please?
Hi @turnoffcallsafenow
there is a mismatch on our server which has kept callsafe active.
I will contact the team responsible to fix this.
Thank you for such a quick response!
We have to re-add CallSafe on your account and then remove it via our server will take about 24 hours to remove CallSafe .  Sorry for the delay, I will let you know when its done.
Many thanks for sorting this issue, much appreciated.
Graham
