on 24-06-2021 12:21 PM
Complain
If you want your voice mail to work either your own or TalkTalk's when a witheld number (NHS Etc) or a non approved number (ie one you did not know would call you), then do NOT use Call Safe as it is not compatible. A CEO (Adam) has been made aware (Tue 22 June 2021) but unless more cusomers complain it is unlikely to be resolved, which is unacceptable.
