on 10-01-2022 11:28 AM
Hi, I've had no dial tone and cannot make calls for the last couple of weeks,
If you ring my phone it just sounds like its ringing to the caller but my phone does not ring.
I've checked everything obvious my end.
I've tried reporting but the phone number but it reported I have a broadband fault,
(which I don't that works fine) and won't allow me to talk to anyone.
Can you investigate please?
on 12-01-2022 09:01 AM
Hi TonyW3
I'm so glad to hear this. You're very welcome 🙂
on 12-01-2022 09:00 AM
Hi Debbie,
Yes I can confirm that its working fine now,
Thank you very much for dealing with this and giving the updates, Its very much appreciated.
on 12-01-2022 08:08 AM
Hi TonyW3
Openreach have now closed this fault - Fault found at the exchange
Has this fault been fully resolved?
on 11-01-2022 01:46 PM
Hi TonyW3
There are no updates from Openreach as yet. I will check on this again in the morning.
on 11-01-2022 08:38 AM
Hi TonyW3
I can see that this fault has now been assigned to a line engineer so we should hopefully receive some additional updates this afternoon.
on 10-01-2022 12:13 PM
Hi TonyW3
The line test has detected a potential fault at the exchange so I have escalated this over to Openreach to be investigated by a line engineer.
We should receive further updates from Openreach within the next 48-72hrs.
