Home Phone
static over line
spirit1
Chat Champion
Message 16 of 16
started having static on my landline this week...plus ocassional lan dropouts, everything checked as per-ususal
15 REPLIES 15
Message 1 of 16
let us know how the test goes.   line tests are not picking up any issues.
Message 2 of 16
ill see if i can borrow one to do a test, still getting static on the landline phone even with new filter, nothing to do with router.
Message 3 of 16
Im afraid the SAGEM is chargeable (£30)  As you have a super router we can only send the same.
Message 4 of 16
i always do that as a matter of course... as a test, may i be sent the sagem 5364 router as a final test..as iv mentioned, my neighbor has same package as myself, with the sagem 5364 and no disconnects, im curious...
Message 5 of 16
Message 6 of 16
new used router arrived d-link dsl-3782, plugged in did speed test via talktalk checker, was getting 12meg download....what
tried it a few times, same result, so i plugged in old router hg-633 ran tests again, speed went up to 20meg download.
my neighbor has the same package as me, they have a sagem 5364 router, and are not suffering disconnects, or speed problems.
the d-link router delivered today had paint on the feet of it, it's a used router and not very good, reading all forum posts about it
i also still have static on my landline...so im thinking, this is a line to the house problem, or from the exchange.
Message 7 of 16
It will be a replacement Super Router, not the WIFI hub sorry.
Message 8 of 16
what model router ? replacement, not the same model i already have, iv heard good things about the sagem 5364, i think thats the correct name.
Message 9 of 16
Message 10 of 16
yes it is, as i mentioned, the engineer even put in a new junction box, tested cables as well, could it be a faulty router.
Message 11 of 16
Hi @spirit1
Line tests are picking up a high resistance fault, Are you connected to your master socket?
Message 12 of 16
sadly...still getting random disconnects, engineer tested all internal connections last week, even replaced junction box..so im assuming its an external problem.
Message 13 of 16
Message 14 of 16
line repaired today 15:00 excellent now, thanks
Message 15 of 16
Hi spirit1,
I'm sorry for the delay. The line test has detected a potential fault so I've passed this over to Openreach for further investigation now.
