How long should it take to uninstall supersafe boost ?
Having problems with supersafe advised to uninstall first but taking forever to uninsall how long should it take ?
Not sure, but best to use this tool to uninstall. https://www.f-secure.com/en_GB/web/home_gb/support-tools
Also make sure you release your licence from the f secure portal so you can reuse it when installing again.
Hi  murrs1,  have you got this problem sorted now?  If not please post back and let us know.
