Need to disable fast 5364 firewall
5 REPLIES 5
In order to connect a new security camera into my network, I need to temporarily disable the router firewall. There seems to be no facility to do this in the router software, only a facility to change the firewall protection level. Can anyone help?
You cannot disable the router firewall, but this should never be required when connecting devices such as an IP camera.
You may need to set up port forwarding to connect to a specific machine or set up Dynamic DNS services to access the camera from outside your local network.
Thanks for your reply. Now I am stymied. One of the requirements to link the light to the router is 'Disable your router's firewall'. I have been trying to get the light (Lutec ESA) to link to the router now for 3 days, including resetting the light, uninstalling the app from the tablet, resetting the router, but it fails every time. I have to switch the light off at night because the flood light is On during darkness and the only way to adjust that is from my tablet via the router. Anyone any further suggestions?
Most decent routers will have firewall protection, and I've never come across any device before that asks that you turn off the firewall before you connect an automation device.
As this will be connecting to wifi, I would advise that you log into the router first, and separate the wifi channels.  To give you an example, I have my 2 channels set as home2 and home5, so I know if I need to connect only to 2.4ghz wifi I just select Home2.
There are a few youtube videos showing how to connect this type of light, but none mention disabling router firewall.  https://www.youtube.com/watch?v=D9hZ_ajwICU
Try searching youtube for other videos to see if they also help with guiding you through the connection process.
Once again, thanks for a quick reply. I disabled the 5ghz chanel as one of my tries, again, without success. I've done everything your Youtube link suggested.
I can only suggest looking at more videos in youtube for additional help.
I could swap out your router for a different model that may have more configurable options.
