Antivirus wont update
3 REPLIES 3
midi48
Hi, i just got back of  a weeks holliday and find my antivirus is out of date. tried updating but it  keeps saying connecting to update server then fails saying cannot connect to server.
I have even uninstalled and reinstalled supersafe but still same problem.
Any ideas please?
 thanks
 carl
OCE_Ady
Hi carl, are you still having problems with this? Our systems are showing that you've got it installed and working and it's definitely in date. If you're still having trouble try removing the software using the Fsecure removal tool before reinstalling it.
midi48
Hi, well for some reason  last eve it updated . I dont know why but its solved itselfe.
 Thank you for reply.
I will see what happens with it over the next week or so.
 thanks
 carl
OCE_Ady
That's great Carl. Let me know if you need any further help.
