I need to turn off Scam Protection.
eillohh
I need my Scam Protection to be switched off. I'm currently working from home and I'm unable to access my work systems because the Network is blocking them. This was switched off by a member of TalkTalk last week and I have been able to access my work systems fine, until this morning where it seems a change in settings has been made in the background. This needs remedy as soon as possible as I'm not able to work.
rutaju
You can go on the blocked website by going to your kids settings!
Go to my account
scroll to bottom and click homesafe
then turn on kid safe if you have it off
It will allow you to select what to block and allow
If you type in the URL in the box the select allow, it should bypass the scam protection
Hope this helps!
Ruta Montvyde
StephenF
Community Manager - TT Staff
Hey,
Sorry for the delayed reply, we're doing our best in these unprecedented circumstances due to the Corona virus to answer everyone as quickly as possible. I'm pleased to confirm that your now able to manage Homesafe settings yourself, from within my account, please follow the below steps to disable scam protection on your line:
  1. Log into MyAccount
  2. Select My Services
  3. Select View HomeSafe settings
  4. Select OFF and confirm when you see the pop up window
Stephen, Community Manager
Our latest Blog l Share your Ideas l Service Status l Help with your Service l Community Stars l Set your preferences
