IP adress and xbox set up
1 REPLY 1
leonhulse
I've recently been hit offline while online gaming on my xbox.
This has prompted me to purchase super safe
I was wondering does this programme protect me from someone obtaining my ip address and also can i set up supersafe to protect my xbox?
Gondola
Hi leonhulse
The article Problems with SuperSafe Boost also gives the compatibility for devices and browsers and you'll see that X-Box is not listed.
Unless you connect via a Virtual Private Network (VPN) then any connection can tell what your Public IP address is. Google search for "My IP" and Google will tell you Your public IP address.
 Gondola - Volunteer 2017-2020
