Supersafe Login fails.
4 REPLIES 4
Bee67
Hi, the supersafe login says my password is invalid.  I follow the instructions to change the password and then log in again.  The same message is displayed:  Invalid password.  It is happening consistently.  Please advise.
OCE_Ady
Hi Bee67, the login is normally the same login you use for MyAccount. Are you able to get into MyAccount ok? If you are and the passwords are the same let me know and I'll force a reset for you.
goerge27
I have the same problem. The password is not accepted and the link is not sent. on one occasion out of about a hundred link was received , password changed. Same result, no access.
Morphy
Please can any one help I am also struggling to download supersafe back onto my computer after having problems with the computer and having to reset. I have been onto talktalk who tried all they could but could not help any further.
I am getting the same I try to log on says (Incorrect login. Please try again) I am on the web now with no protection. Thank you Morphy
Morphy
Thank you I have now sorted the email was going into the junk mail box thank you Morphy
