Supersafe Password
Chris Johnson
F secure will not recognise password to set up Supersafe and then when entering email address as requested no response is coming to email despite trying numerous times.
How then can a new password be sorted?
nicey2k
I am having the same problem.  I order supersafe, but have not been sent a username and password by f-secure.  I tries the "forgot my password" function, but nothing arrives which suggests i havent been set up.
I have contacted talktalk support twice, and both times been told the wrong information.  I will not waste time with them again.  Can anyone here help?
Christof1
Hi @nicey2k @Chris Johnson ,
Have you also tried to check the Spam folders to check if the email has been directed there? This should come from SafeAvenue.
