Unable to work from home
8 REPLIES 8
Melissa_Donegan
This is an urgent issue - I have not been able to work from home for the last few weeks because of new secrity updates.
I ahve called and they say that they cannot help and I will need to put a note on the community.
Please can someone assist asap?
Thanks,
Please can you elaborate, what security updates?
Melissa_Donegan
Hi Keith,
I have no idea what talk talk did to the network.
A few weeks ago I was working from home fine now I am blocked my accessing their vpn.
I spoke with my IT team an apparently this is a know issue that talk talk updates and block me accessing my network drive.
I am able to use my phone data and even Starbucks wifi to connect but not talk talk.
Do you have the DSL-3782 router, if not what router/firmware are you using? The 3782 router does have VPN issues, the HG633 when running the latest firmware (V2.00) is fine, as is the TalkTalk WiFi hub.
Melissa_Donegan
I have the HG633.
I'm not really sure what firmware.
Thanks,
Melissa
I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
OCE_Debbie
Hi Melissa
Melissa_Donegan
Hi Debbie,
Thank you. I have updated my profile.
Melissa
OCE_Debbie
Hi Melissa
I've checked and your router has the latest firmware version, we also don't block the VPN connection.
Did this work previously with this router?
Please can you try factory resetting your router using the pin hole reset for 10 seconds and retesting following this?
