Saying 'hi' & quick question re weak security
1 REPLY 1
Visitor
Hi everyone. Just introducing myself as a total technophobe!
I have the 'weak security' message, and have read the post about it several times.
I just want to check that I am understanding it correctly, and that I don't really need to worry about the message, but can change my router if I'm bothered about the message?
Hope that makes sense...
LP
Hello, you don't say where the message is displayed, I assume it is something to do with your password if this is the case just change it for something 'stronger' by maybe adding symbol  i.e # $ £
