Automated phone call claiming to be from TalkTalk.
Totally wrong @broadstairs.
It add numbers you have phoned recently, automatically, and you can then add those not phoned recently quite quickly via my account.
The only thing you can't do us access the callsafe number listings before activation., but are you really going to get hundreds of calls immediately you've activated it? In reality no, so adding numbers is, as I say, quite quick.
As I previously mentioned, I've not had one scam call in over 2 years.
@broadstairs, I should also add that I have just bought new Panasonic handsets, and am pleased to say that the recorded message for those not in your call list, is now recorded with their name, so you know who phoned. They can't leave a message unless you have approved them, but this is the same with 1571, and now there is a charge for this, it should help others to decide whether to use their own phones voicemail.
I'm pleased it's now working.
Super Duper Contributor
OK but flawed is not really harsh enough, seriously flawed in design and implementation is probably better. However I dont want to have to change my answer phone simply because there is no way to test if it works and I will never use their 1571 service because there is no notification without lifting the phone, and having to pay for it to use Callsafe is in my view not much short of a rip-off.
Stuart
There is a way to test it. Turn it on and call your home phone (or get someone to call it) and see what happens.
Then, once you've tested it and if don't like it, then disable it. It won't cost you anything to try, but to try and rubbish, what many find useful, without having tried it, across multiple threads too, is harsh.
OK, I think everybody has had a fair crack at this. At the end of the day CallSafe is one of a number of tools which can be deployed to help Beat the Scammers which is what this discussion is about. Not the pros and cons of any particular approach, which will always be subject to individual opinion. So let's leave it at that for now please.
Regardless of the efficacy (or not) of callsafe (I have tried it in the pat and found it unsuitable), my main complaint was, and still is, that at least 90% of the nuisance calls I get are this fake TalkTalk scam. (Sidebar, using the block last number feature seems to stop the other calls).
I simply thought that TalkTalk themselves would be a little more pro-active on their part in stopping an apparently widespread scam that was using their name.
If only it were that simple. For every TalkTalk scam phone call, there is probably the equivalent BT scam phone call. It's why BT and TT have their versions of CallSafe that customers can use.
Insightful One
I don't use callsafe but having read the posts in this thread, it is free and seems better than nothing.
Why is it possible for scam calls to be sent from phantom numbers so it is impossible to block them?
The price to pay for having an open international telephone system based on old technology which is capable of being usurped by modern technology I guess. You?
I have had as many as 6 of these calls in a day and have now set a blocker on my phone.
Is Talk Talk aware of these and what are they doing to prevent these unwanted, possibly dangerous, calls?
JamesIII
I am receiving lots of calls from a person/call centre stating they are from Talk Talk and that my internet has been compromised and someone has hacked into it.  They then ask me to log onto my computer so they can help solve issue. I haven’t done so as I believe this is a scam.  I haven’t been a customer of talk talk for at least 5 years.  Despite me telling them that they keep on saying the line is still with them. They  are very persistent.
Hello Sarah
This is certainly a scam.   Do not let them have control of your computer.  The official advice is to hang up on all these calls.  Do not give them any information.
I had to temporarily switch off my Talk Talk call safe service last evening.
This morning my wife received three scam calls attemting to trap her into calling premium numbers:
* A slient call
* A call purporting to be from TalkTalk asking her to press 1 or 2
*  A call purporting to be from Amazon saying our membership was increasing to £39.99
I've since reported all three numbers under the Talk Talk scam calls. They are all unreported numbers and they are logged as seperate events.
I believe it is important that the community are aware of the timing of calls cacading in the day following the protection being switched off, is there a trigger scammers can use to see defenses down or something esle?  Any views?
I have since reactivated call safe.
I don't use call safe because it doesn't let automated security code calls from my bank through and if when I know one is coming I turn it off temporarily all my saved lists are deleted. So for me that makes it completely useless i'm afraid.
Rich
Rich, yes the deletion of lists is a real pain.
Before i was with TT i was with BT,
Now i get calls saying there going to cut me off today unless
I press a  number on key pad they asked for.
just reply can you hold while i trace your number please
and strangely enough the line hangs up lol.
there getting your number from the your not with held number.
Another BT one i get is there is a problem with your rooter it shows its running slow ect.
I tell them what rooter they say your BT one
I say lats strange i don't have one there  line hangs up lol.
Or just say ill go get the account holder and leave the line open.
Never ever give them access to your pc phone ect there after your bank details.
hi dear
I just want to warn everybody to don't switch your computer or don't give your mobile number and if you are with talk talk tell them you are not and ask them to call back later because you are busy and then contact what ever your service provider is and ask tell them about the incidents they will tell you what to do this people are targeting all provider and they are from india or pakistan accents so be aware they will try all the truck even they can stop your broadband to show you that they are real so just tell them you are busy you will call later it's big firm who operate all round europe and they can call your mobile as well
Anyone know how to speak to an agent from talktalk
Lucy Newbanks Love to do makeup
