Android Mobiles not connecting to home wifi
ANSWERED
13 REPLIES 13
Linda Mae
Basic home set up - no frills.   TV, laptops, tablet, kindle all connect to the home wifi.
Both our andoid mobiles(different makes) stopped connecting to the home wifi a week or two ago.  They had previously been connected for at least a couple of years. They both connect to external mobile networks. Various messages appear - mainly 'Authentication error occured'  - sometimes 'Network may not be available'
If I change the IP setting on my phone from DHCP to Static then look online at the Router settings, it shows the phone as a connected device. But there is still no actual connection.  Initally the IP address showing for my phone was different from the IP address in the phone. I changed it on the phone to match what was in the router settings. It connected VERY briefly but I am now back to no connection.
If anyone has any ideas I would much appreciate it.
It may be that the Androids are trying to connect to the 2.4GHz WiFi band, whilst the other WiFi devices are connecting to the 5GHz band and the 2.4GHz band is suffering from interference. Slow speed, intermittent dropouts, breaks in the signal, or no signal on some or all devices, might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi.
If you have the HG633, HG635, DSL-3782 or the TalkTalk Wi-Fi hub, they are dual-band routers & offer both the older 2.4GHz & the newer 5GHz Wi-Fi bands. The problem is these are two different networks (SSIDs), but they share the same name, so you can't tell which one you are connected to. Log into the router (http://192.168.1.1) and enter a username of "admin" and if the HG635 a password of "admin" as well, or if the HG633, DSL-3782 or the TalkTalk Wi-Fi hub, use the unique router password (see the label on the rear of the router at the top).
HG633/635 go to:-
"Customise my wireless network"
Append "5G" to the end of the network name of the "Wireless 5 GHz SSID" field. Then click "Save".
DSL-3782 go to:-
Settings > Wireless (Wi-Fi)
Append "5G" to the end of the network name of the 5 GHz "SSID" field. Then click "Save".
TalkTalk Wi-Fi hub
Go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 5Ghz gear icon > Basic
Append "5G" to the end of the network name of the "SSID" field. Then click "Apply".
This will not fix your issues, but it will make it much easier to identify the band you are connected to. This way you will know which band is causing your problems.
You may then wonder what was really the point of this if it won't solve the problem? This is because the whole topic is too complex to be dealt with in one post. The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
Linda Mae
Keith, thank you so much for your reply. We have the HG633 router, and I have done as you suggested and put 5G into the relevant band name so we can differentiate between the 2 bands. You are correct on all counts -  it looks like the laptops and the tablet were connecting to the 5G (and we have reconnected those), and also it doesn't solve our problems! Neither of the phones is seeing the 5G band at all.
If you are able to send me your guide that would be much appreciated. How do we go about this do you need an email address?
With many thanks
Linda
Hi Linda,
No I don't need an email address, I will attach it to the bottom of this post.
Please see my attached guide on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone & Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots that I have requested in my guide, from the analyser you are using (also in my attached guide). Please ensure that the analyser is maximised (if Windows) before taking the screenshots & upload them via the "Photos" button on the post editor's toolbar as large images. If they are too small, I will not be able to read them & although I can enlarge them, this just puts the text out of focus. If you prefer PM them to me. If you do PM me, then please add a link in there to this thread, so as I can find it easily.
Linda Mae
I am away from home for a fortnight so will be back to you after that. Thank you so much.
With bèst wishes
Linda
Linda Mae
OK so doing our best here: We don't appear to be able to 'unhighlight' the 5G network because that's the one the PC is connected to. The signal strength screenshot looks the same whether the 2.4 i highlighted or not so there is only one screenshot of that attached. Many thanks.Interference 2.4 PNG.pngInterference 5G PNG.pngNetwork Quality 2.4 PNG.pngNetwork Quality 5G PNG.pngSignal Strength PNG.png
Your 2.4GHz WiFi band looks pretty good to me, although I would always recommend setting the 2.4GHz channel bandwidth to 20MHz only. Currently you can get away with 40MHz bandwidth, but you never know when somone else starts to use a channel in the range of 9 channels that you are currently using. I would keep it on channel1.
Where the 5GHz band is concerned, you could move to channel 52, but bear in mind that not all network adapters in your devices support this higher channel (although they should).
All instructions on how to this are in my guide.
Linda Mae
Hi Keith
I have changed the 2.4GHz bandwidth to 20MHz only, and have set the channel to 1 rather than Auto, and have switched everything on and off for good measure,  but we are still getting the same issue. Either 'Authentication error occurred' (my Samsung), or just no recognition of the network at all (his MotoG). Neither is a particularly cutting edge phone so neither one works with 5Ghz. A further point is that now that we have differentiated the 2 networks our laptops can't connect to the 2.4GHz, only to the 5GHz.
Thank you so much for all your help, if you have any further thoughts we would appreciate it.
With best wishes
Linda
Solution
I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
OCE_Karl
Hi Linda Mae
I've another router on the way as this looks to be at fault.
Linda Mae
That's perfect - many thanks.
Linda
OCE_Karl
No Problem 🙂
Linda Mae
For info - the new router did not initially solve the problem.  We had to go through the steps outlined above of differentiating between the 2.4 GHz and the 5 GHz networks. Not sure of the logic of this given that it didn't help with the previous router, but pleased to have a solution.
OCE_Arne
