Mobile support
For any questions about your TalkTalk mobile service.
Doogee Max 5 Pro no data connection
FranT
Message 3 of 3
I'm having problems connecting my Doogee Max 5 Pro to mobile data. I can use wifi and make calls, texts etc. I've checked the APN settings are the same as on the Talktalk help website and mobile data is on (wifi is off). Any suggestions?
Message 1 of 3
Have you put your phone into this checker ?
https://willmyphonework.net/
Try setting "preferred network type" to 3G
Gondola
Message 2 of 3
Hi Fran
It'll work on 3G but not on 4G.  Have you got 3G coverage in your area? Network coverage (Click here).
Later in the year there's going to be a new mobile offering from TalkTalk and we expect that will include 4G.
GondolaVolunteer 2017-2021
 Like below to appreciate my help . . . Mark as solved + Accept as Solution
