Mobile support
For any questions about your TalkTalk mobile service.
Essential SIM - minutes left ?
trusadh
Message 5 of 5
I recently received an Essential SIM for intended use as 'a backup' in my old (non-smart) phone. I have met a problem in easily seeing the minutes used/left:
"My Account" on a PC is always very slow to load and sticks at "Preparing dashboard" - a reload of the page usually eventually loads the page (I use the latest Firefox and disabling Adblock makes no difference). The usage information only seems to be updated for the following day and is not immediately accurate.
Cannot use the "My TalkTalk App" on a non-smart phone.
Is there some sort of a short dial code to return the usage as, e.g. with GiffGaff ?
Any other acceptable solution?
Thanks to all.
4 REPLIES 4
Message 1 of 5
Thanks for your great assistance Gondola - much appreciated!
Message 2 of 5
...absolutely right. The SMS usage alerts are part of the TalkTalk package and come through automatically.
There are the usual limitations as with any mobile phone service in the real-time reporting of usage so you do need to bear that in mind. The 'accuracy' is going to be more relevant to heavy users than light users.
GondolaVolunteer 2017-2022
  Like below to appreciate my help . . . Mark as solved  Accept as Solution
Message 3 of 5
Thanks for the suggestion Gondola.
Looks like the Usage Alerts will be automatically sent by default and do not require to be set up or requested?  However, still seem to be subject to a delay and not 'real time'.
Gondola
Message 4 of 5
Hi @trusadh
I'd suggest you set up a Usage Alert.
