Mobile support
For any questions about your TalkTalk mobile service.
Swap Talktalk mobile SIM.
Grumpyolduser
Message 2 of 2
Hi, I'm soon to change my mobile 'phone. The new one uses a different size SIM. All I can find on the Talktalk system is "Contact us".
Previously this was very straightforward but I just can't seem to be able to get a handle onto which actual "Contact us" to use.
Got to be obvious but I'm having difficulty here.
Any help appreciated.
1 REPLY 1
Gondola
Message 1 of 2
Hi Grumpyolduser
I used Live chat messaging, asked for TalkTalk Mobile about a SIM swap and was put through to the team that organised a replacement SIM.
LiveChat to TalkTalk support is here:  Our LiveChat team.  Wait for the light blue Chat now button to appear; It's grey or clear when busy or offline.
Opening hours are here:  When to contact TalkTalk?
TIP - Pause tracker blocking in the browser, ad-blockers and similar blocking software to avoid conflict with LiveChat's operation.
Calls to Customer Services on 0345 172 0044 TalkTalk Mobile, option 1,  are free from a TalkTalk home 'phone but otherwise are at a standard landline call rate.
For calls to Customer Service agents from a mobile, use 0203 441 5550 or to contact TalkTalk Mobile it's 0800 458 5331.
TalkTalk supports the Text Relay Service: It's 18001 then 0345 172 0088.
GondolaVolunteer 2017-2022
  Like (below) to support me . . . Mark as solved (below)  Accept as Solution
