Mobile support
For any questions about your TalkTalk mobile service.
Unlock iPhone 6
simon1688
Message 15 of 15
How do I get my iPhone unlocked if I'm using talktalk sim card?
14 REPLIES 14
stevehornberger
Message 1 of 15
I just saw your question regarding “unlock iPhone 6”, If your problem is not resolved yet, i'd recommend you to browse https://www.unlockninja.com/unlock-apple+iphone-6  & follow the steps to resolve your problem. I hope you will get solution from this web portal Safely, Legally, Quickly, Forever!
Thanks,
stevehornberger
Message 2 of 15
Thanks,
Message 3 of 15
hi simon,
In which case you may need ot contact vodafone to get the handset unlocked.
Cheers
Message 4 of 15
It doesnt display a message that its unlocked ann when I try another sim in the mobile it says it needs ativating
Message 5 of 15
hi simon,
What happens when you try and follow those steps?
Cheers
Message 6 of 15
It doesnt work, looks like I have to get a Vodafone pay as u go sim to unlock it ???
Message 7 of 15
hi simon,
If the phone was bought from voda and wasnt locked becuase of the TT sim, either the above process will work, or you need to contact vodafone for an unlock code.
Cheers
Message 8 of 15
Mark I bought it from Vodafone so its locked to their network, I am no longer with Vodafone as I am now with talktalk.
Message 9 of 15
hi simon,
can you try the following steps
STEP 1: Once your SIM has been activated, connect your iPhone 6 or iPhone 6 Plus to computer and start iTunes.
STEP 2: Now press on the restore button and it will start restoring your iPhone. Make sure you create a backup before doing this, as it will erase all your data.
STEP 3: Once the restoring process has been completed, it will show a message saying your iPhone has been successfully unlocked.
Cheers
Message 10 of 15
hi simon,
Im just trying to establish if the phone locked to your TT sim when you first put it in. Have you tried to resync itunes with another networks sim in your phone?
Cheers
Message 11 of 15
Of cos I have no other sims work only Vodafone
Message 12 of 15
hi Simon,
Have you tried another sim in the phone to confirm it is locked?
Im looking for a thread another customer posted a few months ago, they had the same issue and were able to change sim by resyncing their Itunes and reconfiguring the phone. When i find it ill post a link.
Cheers
Message 13 of 15
anyone know the answer?
OCE_Mark
Retired
Message 14 of 15
hyi Simon,
I believe you can actually do it through Itunes and selecting the new carrier.
Cheers
