Mobile support
For any questions about your TalkTalk mobile service.
Used minutes warning
danco
Super Duper Contributor
Message 2 of 2
I am on the Essential SIM plan, with 200 free minutes.
Recently got a text to say I had 30 minutes left for this month.
Is there some place where I can add further text warnings (say, at 10 and 5 minutes) or is this done autmatically by TalkTalk?
1 REPLY 1
Gondola
Message 1 of 2
Hi @danco
Here's the current information about the free usage alerts from TalkTalk (Click here).
The two alerts are set at 80% and 100% and are sent just to the mobile that's got to that level.  There may be a delay in you receiving that alert triggered by the reaching of the percentage level just because the alerts are sent only in normal usage hours.
It's a great idea to have additional alerts, maybe in association with the usage app MyTalkTalk. Why not suggest an Idea?
GondolaVolunteer 2017-2021
 Like below to appreciate my help . . . Best answer is + Accept as Solution
