As you know, here at TalkTalk we're always working to make our broadband as good as it can be. Now you can help too. We’re delighted to invite you to take part in a trial with SamKnows, the world leaders in broadband measurement. They’ve partnered with Ofcom to research broadband performance across the UK and this is your chance to play a part.
What does the trial involve?
All you need to do is connect your TalkTalk router into a device (a whitebox), this will then measure your broadband connection. Please note - your internet usage won't be recorded – only the quality of your connection.
When you volunteer you'll be given access to a secure online portal. There, you'll be able to see all of your own data, allowing you to follow the performance of your connection as well.
Where do I sign up?
If you're interested in taking part in this trial, all you need to do is sign up with your name, email address, postcode and the name of your ISP which is TalkTalk.
If you have further questions about the trial, take a look at the installation guide and FAQ's on the SamKnows website.
