Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
A time-out setting at TT's end?
KeithDM
I recently installed a new NetGear DGN 2200v3 (replacing an old TT freebie DLink) as I wanted stronger wi-fi and a more robust Adsl connection. TheNetGear has met these requirements very well indeed. However (isn't there always an 'however'!) whilst the connection to TT is now consistent, if I turn off all devices at bedtime (i.e. PC's, laptops, tablet & put iPhone into sleep mode), in the morning the connection is down and I have to reboot the router. If I leave a device active throughout the night, the connection does not drop. The time-out setting on the router is 'always on'. Therefore is there a time-out setting at TT's end?
babis3g
Super Duper Contributor
i mainly posting to say i don't think there is sleep timer at TT end
It must be a setting (maybe save energy or sleep timer or under the name "time out when connection is iddle for....min" etc
So check modem or router wi-fi settings
KeithDM
Thanks. As per my original post, the router's 'Idle Timeout' is set to 'Always On'. So unless there is another timeout setting hidden away in the router (DGN2200v3) then I'm somewhat stumped.
Banned
Odd one this, have you checked if there is a firmware update available for your router?
KeithDM
Odd indeed. Have just checked (again) for a software update and the result shows mine is up to date.
Banned
OK, as a workaraound you could try and enter 1,440 minutes (24 hours) in the idle timeout box, see if that works?
babis3g
you have set it at always on
what are the other options there?
KeithDM
There are three settings 1. Always on. 2 Dial on demand. 3. Manual connection.
Only No. 2 allows a figure to be put into the Idle Timeout box, and then of only two digits.
babis3g
To the time out box add manually "0" or "00" then save
I am sure is not TT...
You may need check your user guide and also this guide from netgear may help you
kb.netgear.com/app/answers/detail/a_id/1134
The value can be set higher, or to 0, meaning the router never logs out. Consult your manuals for instructions.
Banned
OK, it may be that the DHCP leases are expiring, you should be able to adjust those timings, not sure where the settings are for your router though.
KeithDM
Thanks. As per my posts #1 & #3, the router is set to 'Always On', which automatically puts a zero in the Idle Timeout box.
Looks like I will have to query this with NetGear - or leave something active all night!
KeithDM
Have trawled the NetGear user manual to no avail. Am currently in contact with NetGear live chat in search of a solution...
KeithDM
Ref my last post, a lengthy typings to and fro session with NetGear resulted only in advice to alter the MTU size to 1400 bytes and info that the Idle Timeout setting is for the DHCP leases. My modem is only a couple of weeks old but the NetGear Support person also advised to got to gearhead.netgear.com/ukhome.html where paid advice is available!
jcampy
try there forums to see if anybody has any idea
babis3g
or maybe just a master reset may helps eluminate if is bug(optional load latest firmware again then master reset again)but do all settings from the begin either with just master reset and not use back up file
Had a quick look around and are some having same issue with different models
Some they blame dhcp (which leased time i am sure not change every 24 hrs) and some blaming the netgear it self
KeithDM
Thanks everybody. I'll have a trawl around the NetGear forum etc tomorrow, see what I can find.
anker
Hi may be a silly question :s you say that you turn off all devices at bed time, does that include the power to the router ?What happens if you leave the router powered on overnight ?
KeithDM
Cough - you are quite right in first sentence! The router is of course left on 24/7.
anker
:o:osorry about that ;) My bad ( a PC dummy )Was only trying to help:)
Crusher2011
Wise Owl
KeithDM, If your router permits have a look at Server Settings.
Ensure DHCP Server is Enabled and Lease Duration is ticked for Permanent Lease.
