Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
Boosting wireless signal
benrees
I have a new TalkTalk Huawei HG533 Router which is working fine and I am very happy. However, I would like to buy a wireless booster / repeater to take out some blackspots where the wireless signal is intermittent and slow. I want to make sure that the repeater I purchase is compatible with the new router so have looked at the huawei ws320.
Is this the correct approach?
Should I be worrying about compatability of different manufacturers?
Has anyone experience of boosting the wireless signal with the HG533 router?
thanks
eebdsirhc
I use the WS320, with a TalkTalk D-Link 2780 router, no problems.
It supports all the usual wireless encryptions and b/g/n transmission.
Buy from Amazon, I found their prices to be just as good as anyone else's, plus it's far easier to send things back and get a refund if it doesn't work as expected.
Swordfish97
Super Duper Contributor
I use a Netgear WN2500RP Extender with a Netgear DGND3300 Router.
The Extender will also work with the TT Dlink 2780 Router (my previous setup).
I don't see any problems extending the signal from your router using the Netgear model.
You should find this on Amazon.
benrees
thanks for your helpfuln responses. i will give it a go and see how it goes. many thanks
