Search instead for
Get Searching
Search now
Get stuck in
Try now
Join the party!
Register now
DLINK DSL-3780 Port Forwarding & Firewall
1 REPLY
smithgt
I'm trying to open up my new TalkTalk router for a VNC connect and for my CCTV webpage.
I've created two entries under the Virtual Server for the port 80 and the range 5800-5900, however if I visit http://www.yougetsignal.com the ports are reported as closed.
Is there a stage I'm missing?
Hi ,
did you have the servers up and running when you checked the ports?
