Fibre Speed Boost
Hi Ban94,
DLM should hopefully continue to increase the speeds over the next couple of days 🙂 Could you bump your thread again on Friday and we can re-check this again for you.
Ban94
No problem thanks
Ban94
Hello, is somebody able to recheck my DLM for any signs of improvement?
Thank you
the current profile is set at the highest level of 80/20.
Ban94
Hello Karl, thanks for the update, I've logged into my router and have some stats for you guys to take a look at. The downstream line rate has been increasing since using the test socket and is now sitting at around 65mb. My question is, whether this is the stat that should be at around 80/20 that you mentioned my profile is set on? If so, is it expected to keep increasing over the period.
Thank you
Line Quality
Upstream line rate (kbit/s):
13941
Downstream line rate (kbit/s):
65513
Upstream noise safety coefficient (dB):
5.7
Downstream noise safety coefficient (dB):
4.6
Hi Ban94,
Thanks for keeping us updated and I'm glad to hear that DLM has increased the sync speed. The current sync speed is within the predicted speed range for the line and the throughput speeds (speed test results) are usually around 80% of the sync speed.
Ban94
Hello Michelle, how long do I have to keep the router connected to the test socket.
Hi Ban94,
If you would like to move the router back to its original location then this would be ok. Just to advise if the sync speed does drop following this then this would suggest a potential issue with the internal wiring. Let us know how you get on 🙂
