My Exchange Pot Sync Speed has Increased - Can my profile be improved?
Lasertek
Whizz Kid
Message 18 of 18
Last November I had problems with mega slow download speeds. This was eventually resolved by putting me on a fixed 4mb?
Since then this has been fairly stable, but recently encounrering some suprisingly high downloads then very low.
With this I noticed that my reported Potential Syncronisation Speed has increased from 4.3Mbps to now 8.5Mbps.
My equipment and location are identical and are fully functional
Can my account profile be changed to suit this new speed increase, please advise?
1 I am using the exchange at Kenton Exchange - Newcastle upon Tyne - 2.06Km straight line.
2 There is NO congestion it shows LIVE and there is no OUTAGE
3 I do not have any telephone extensions
4 I am connected directly to the BT NTE5 installed socket
5 I do not have any voice problems with the telephone
6 I am using a EchoLife HG520b RJ45 hard wired
7 I am Not using any extension lead
8 Line Attenuation see below
9 The SNR is see below
10 ADSL2+
11 Sync Rate see below
12 see below
13 I am using the latest Bullguard IS v8.7 with 2 hour updates
14 Speed test - see my speedtest results
15 I am recently suffering slow download speeds
16 Not checked
17 I am suffering expected slow speeds when browsing.
Data Path Interleaved
Operation Mode ADSL2+
Bandwidth Down/Up(kbps) 6409 / 877
SNR Margin Down/Up(dB) 8.6 / 9.4
Attenuation Down/Up(dB) 45.0 / 25.2
Power Down/Up(dBm) 0.0 / 12.3
CRC Down/Up 7507 / 65512
FEC Down/Up 51985 / 65514
HEC Down/Up 44727 / 0
System Up Time 37:19:56
DSL Up Time 10:00:41
PVC Select PVC-0
PPP Up Time 10:00:41
17 REPLIES 17
Chris-TalkTalk
Message 1 of 18
Hi Lasertek,
Sorry, don't know what caused the speed to drop then improve again, may have been intermittant noise on the line
Please let us know if the speed drops again
Lasertek
Whizz Kid
Message 2 of 18
Yes it has, now back to my normal speed of approx 4Mb.
Any specific reason for this, without any intervention?
Chris-TalkTalk
Message 3 of 18
Hi Lasertek,
Your sync speed seems to have improved - what's your download speedd like now?
Downstream Rate 7068 kb/s
Upstream Rate 785 kb/s
Downstream SNR 7.1 dB
Attenuation 45 dB
Thank
Lasertek
Whizz Kid
Message 4 of 18
Hi Guys, since my last posts all has been ok, but over the last few days my speed has dropped again, making programme update downloads painfully slow.
Bandwidth Down/Up(kbps) 5117 / 801
SNR Margin Down/Up(dB) 12.3 / 11.5
Attenuation Down/Up(dB) 45.0 / 24.9
CRC Down/Up 36315 / 65498
FEC Down/Up 22612 / 0
HEC Down/Up 4950 / 0
System Up Time 1748:12:52
DSL Up Time 13:06:42
PVC Select PVC-0
PPP Up Time 13:06:41
Nathann
Message 5 of 18
Hi Lasertek,
BuffsMad is right, the IP addresses are not yet listed on the speedtester database.
Nathan
BuffsMad
Message 6 of 18
Originally Posted by Lasertek
My connection since the last post has been stable and the speed has been average, but acceptable.
Today I have performed two speed tests and noticed that they have been recorded as 'non talktalk' results? Any ideas as to why? Thanks
Their just rogue/new IP addresses - they have yet to be added to the speedtester database so they show as non-TT. Starts 92.XXetc.;)
Lasertek
Whizz Kid
Message 7 of 18
Nathann
Message 8 of 18
Hi Lasertek,
Your SNR margin appears to be varying which could be the cause of the slow throughput, it looks like there may also be some drops in connection. I have backed the profile off to 12db interleaved which should give a greater margin.
Downsteam Rate 6307 kb/s
Upstream Rate 797 kb/s
Downsteam SNR 11.8 dB
Attenuation 46 dB
Nathan
Lasertek
Whizz Kid
Message 9 of 18
Download speeds now seem constant over the afternoon of 4-5Mb. But why the improvement from the earlier 0.5Mb when the profile has not been changed? TT Network?
If available a logical explanation would be appreciated as to why the wide speed range from ultra poor 0.5Mb to average 4-5Mb speeds with no profile or equipment changes.
I had this problem last November that lasted 1 month, and the only solution then was a 4Mb fixed profile? This has lasted fine until this week. Could it be my Kenton exchange current upgrade to over 8Mb causing my problems?
I will monitor this profile without any changes for a further few days, and hope that the download speeds stay constant.
Bandwidth Down/Up(kbps) 6749 / 837
SNR Margin Down/Up(dB) 9.6 / 9.1
Attenuation Down/Up(dB) 46.0 / 25.2
CRC Down/Up 42359 / 65504
FEC Down/Up 17788 / 65528
HEC Down/Up 40593 / 0
System Up Time 72:27:22
DSL Up Time 9:53:03
Lasertek
Whizz Kid
Message 10 of 18
Hi Debbie,
To date the 24ISNR9 profile is good and stable. I think my line does not like any noise lower than a 9 setting.
I have just started to experience ultra slow downloads. This is a s low as 190kbps and some of some my software updates are timing out due to being so slow. However the browsing is fine.
I do not know if it is the new profile or a network glitch (10.40am).
Edit.. 09:40 Sat My download speed is still very slow (500kb) and all attempted downloads are self timing out or breaking part way through.
I had this same experience last November where many profiles were attempted, and the final profile was a fixed format? Was there a reason for this and should I be put back to this type?
Edit.. At 15.30 Sat My speedtest was 5Mb+ and dowmloaded my software updates fully with no breaks.. I expect speed test discrepencies but Why the such a large difference 0.5 to 5.0+..? Is it all down to my current profile 24ISNR9 or the actual TT Network \ Exchange?
Please advise..Latest Router Info below..
SNR Margin Down/Up(dB) 7.3 / 9.1
CRC Down/Up 48653 / 65504
FEC Down/Up 57044 / 65528
HEC Down/Up 51311 / 0
System Up Time 67:50:35
DSL Up Time 5:16:16
Message 11 of 18
Hi Lasertek,
How have you found the connection since the profile change?
Lasertek
Whizz Kid
Message 12 of 18
Hi Ady,
Instant speed improvement with a 5.7Mb speedtest.
My 'old' post was on the second page when you were answering all new page 1 posts, thus wondering as to why? So bumped my post to page 1.
Anyway, thanks for the profile change. I will monitor.
Ady-TalkTalk
Message 13 of 18
Hi Lasertek,
we work oldest to newest posts if you bump you push your thread to the back of the queue again.
Sorry its taken a while to get to you, I have changed your profile to 24isnr9.
Lasertek
Whizz Kid
Message 14 of 18
Hi Ady.
I see that you are active and was wondering why my request has had no response? Please advise asap.
Lasertek
Whizz Kid
Message 15 of 18
Since my 5:58pm report last night I have been unable to successfully view pages due to the ultra slow connection speeds since my profile change yesterday.
It has also taken me since 9am this morning to gain access to this page to write this report.
Please check my profile account and change \ revert back where necessary.
Lasertek
Whizz Kid
Message 16 of 18
Hi Ady,
My browsing has nearly ground to a halt. It is that slow the speedtest will not register.
Please advise if this is this profile or the TT exchange with problems?
Ady-TalkTalk
Message 17 of 18
Hi Lasertek,
I have moved you onto 8ISNR6 that should help. I am currently unable to see your status as our tool is misbehaving.
Let us know how you get on.
You will receive a customer satisfaction survey within the next week regarding your experience of using the forums. If you could spare a moment to complete this it would be appreciated.
