Password security improvements.
15243p
Message 5 of 5
I noticed that I can't paste complex password into the required areas for the network password, router log on, WiFi password and Talktalk email account.
I think having the ability to copy and paste complex passwords from key safe or similar would be a bonus.
4 REPLIES 4
Message 1 of 5
I've not noticed working in the past.
It's always been the same for me, at least.
Typing into the entry fields work fine.
Key-safes are useful for storing dozens of passwords for websites and devices, it's a lot easier than trying to remember them.
I just thought that pasting into the password creation/entry fields would be a plus.
The router issue isn't really a problem, I'll just remember to change the WPS and encryption settings from the defaults if the wireless is toggled on and off.
Message 2 of 5
Hi 15243p,
Has this previously worked? Has this just only started happening? Does it work if you type the password in?
In regards to the router losing its settings, do you have a different router that you can test with?
hosay299
Message 3 of 5
@15243pI have used copy and past on the site areas and works fine for me too
what browzer are u using to do it on
Message 4 of 5
I have just tried that and copy and paste works fine. Have you checked that the complex password you are trying to use meets the criteria for the fields in question?
